87 or E85 ?
CarCat
I just bought a 2008 Ford Edge Limited from the original owner/private party. I know nothing about the Edge.  Engine is V-6 3.5L .  Owner's manual specifies to use 87 octane unleaded gasoline. However, the gas cap has an E85 label stuck on it. Do I ignore this E85 label and follow the owner's manual?
Welcome to the forums!
I would reach out to the seller and ask him which type of gas they used etc.  I do not recall any of the edge models to be flex fuel compliant. The previous owner may have performed a conversion.  Or when in doubt if the vehicle has a E85 sticker it should run fine on normal gas till you are able to get a definitive answer from the previous owner.
Edited by onyxbfly
