IWRBB Posted August 30, 2019 Report Share Posted August 30, 2019 Does anyone have issues with the sunroof shade making noise over bumps? Our does it a lot. It sound like the fabric is smacking the center cross piece between the two pieces of glass. It's not very taut and being one long piece, it's plenty flappy enough to move up and down and hit the cross piece. Open it up and there is no noise. The shade on our 2010 was made of more substantial material and didn't move around at all. It was also split into two parts which totally prevented it from hitting the middle cross beam as well. It also blocked the heat better. Seems like the 2019 shade is vastly inferior to the 2010 IMO. It's neat in that it's all one piece as it rolls back, and there is no fat headliner material over the crossbar so it seems more open- but man, everything else about it seems so cheap and flimsy. Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 30, 2019 Report Share Posted August 30, 2019 Fix it under warranty. That is not normal, the shade on my 2016 is as sturdy as my older 2011. As far as I know, the 2019 has the same shade as 2015+ models. 2 Quote Link to comment Share on other sites More sharing options...
pmbb68 Posted December 15, 2019 Report Share Posted December 15, 2019 Our 2019 sunshade does not make any noises no matter how bad the road dips or holes. Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted December 16, 2019 Report Share Posted December 16, 2019 A warranty fix for sure. My '16 makes no noise at all (except the pleasant whrrrrr as it opens/closes). Suggestion, go to your Ford dealer and sit in another late model Edge. Try pushing up on the sun shade and compare it to yours. If there's a difference it will be something you can point out to the service writer. Quote Link to comment Share on other sites More sharing options...
Sage Posted December 16, 2019 Report Share Posted December 16, 2019 I have not heard anything from mine. Quote Link to comment Share on other sites More sharing options...
MENINBLK Posted January 8, 2020 Report Share Posted January 8, 2020 The shade on my 2019 rattles something fierce. I am going to inquire about it at my next service visit. Quote Link to comment Share on other sites More sharing options...
IWRBB Posted January 20, 2020 Author Report Share Posted January 20, 2020 We haven't taken it in yet as we'll need to strip everything out of it first, but let me know if you find anything on yours. Quote Link to comment Share on other sites More sharing options...
Tom H Posted July 3, 2020 Report Share Posted July 3, 2020 I have a 2019 Ford Edge SEL. Bought it in Sep 2019 new. The sunroof makes a noise when going through dips and bumps. Took it to the dealer twice now and am told it is normal noise. This is the 3rd Ford Edge I have had with the Panoramic sun roof and there was no noise in the other 2. The dealer won't even look at it. We go for a drive and they hear it then send me on my way stating it is normal noise. Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 3, 2020 Report Share Posted July 3, 2020 On 7/3/2020 at 3:53 PM, Tom H said: I have a 2019 Ford Edge SEL. Bought it in Sep 2019 new. The sunroof makes a noise when going through dips and bumps. Took it to the dealer twice now and am told it is normal noise. This is the 3rd Ford Edge I have had with the Panoramic sun roof and there was no noise in the other 2. The dealer won't even look at it. We go for a drive and they hear it then send me on my way stating it is normal noise. Expand I have 2 sounds from the sunroof. 1 is from the friction between the rear part of the movable glass and the seal. Cleaning the seal & glass surface where they meet. Some light grease also helps. 2 is from the rubber surround under the glass, this rubber doesn't seem to have a function as it doesn't seal anything, probably for sound purposes. This rattles a bit. Quote Link to comment Share on other sites More sharing options...
