spark knock
Michael J. Drake
Welcome to the forum!
Modern engines use sensors to detect pre-ignition way before we can hear it and dial back timing.  "Spark knock" shouldn't happen without getting an error code indicating a sensor has gone bad.
That said, I don't know what else might be happening that sounds like pre-ignition when accelerating.  If you have a code reader or auto parts store that'll let you borrow one you might want to check it for 'pending' codes.
Edited by Gadgetjq
how many miles on your Edge?  have the plugs/coils/pcv valve been serviced yet?
could be bad fuel or sticking injector(s).  if this just started happening, check to see if a changeover to winter fuel has occurred in your area.  run a bottle of HEET (yellow) thru the tank, see if that helps.
does the CEL flash at any time during this event?
  • 3 months later...
