jharry3 Posted August 29, 2019 Report Share Posted August 29, 2019 I am looking for a diagram of which cylinder is number 2 in the 2.0 liter Eco Boost? CEL came on this morning. I read the code with my code reader. My understanding is this is the number 2 in the firing order , not a sequential left/right or right/left number. I seem to have 3 choices, from cheap to expensive, to fix this: 1) Spark plug, 2) coil pack, 3) fuel injector. I'll do spark plugs first since the wife has almost 70k miles. If that does not solve the problem then I need to look at the coil pack for that cylinder. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted August 29, 2019 Report Share Posted August 29, 2019 She's two years old with 70k miles on her. She still has many miles and many years of comfort and service left in her. With 70k she falls under sever duty maintenance. Your path of resolution makes sense and are all things that require changing at some point. Mac T has an awesome website. On his DIY maintenance page he has the firing order listed as 1-3-4-2. https://www.mactgarage.com/gen-2-ford-edge-capacities-and-spec If you dig around the diy maintenance section you may or may not find a map that will help you in your quest for maintaining your edge. Here is a hint to help you get started. Point your browser in this direction https://www.mactgarage.com/ HTH 1 Quote Link to comment Share on other sites More sharing options...
handfiler Posted August 29, 2019 Report Share Posted August 29, 2019 You can also move the suspect coil to another cylinder and see if the misfire follows it. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 30, 2019 Report Share Posted August 30, 2019 Firing order is defined in terms of cylinder #, not the other way round. Cylinder numbering is 1 2 3 4 as you look from left to right (pass side to driver side of the engine). On an ecoboost, could be a spark plug or fuel injector. If plug is bad, replace them all. You have not stated mileage on your 2017 ... 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted August 30, 2019 Report Share Posted August 30, 2019 17 hours ago, jharry3 said: I'll do spark plugs first since the wife has almost 70k miles. 2 hours ago, WWWPerfA_ZN0W said: You have not stated mileage on your 2017 ... I may have interpreted it wrong, but I understand it to mean that his wife's edge has 70k. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 30, 2019 Report Share Posted August 30, 2019 you sir are absolutely correct! In any case, seems to be a fair bit of annual mileage on the vehicle, so you would not think typical severe operating conditions type issues. But never hurts to start with looking at the plugs, as they tell the story of what is happening inside the engine. 1 Quote Link to comment Share on other sites More sharing options...
