Hack! How to cut 1/0 4 gauge etc. wires cleanly...
I searched a lot on what to use to cut 1/0 amp/weld wire and saw everything from using a disc cutter (dremel) to hacksaws and a few other things.  Once thing I did not see was to use... bolt cutters.  I happen to have one that I use when I installed closet maid shelving (to avoid using hacksaw).  I was stunned at the super clean cut I was able to get even on the 1/0 gauge power wire I am installing for my new set up.  If you are looking for options and do not have a proper cable cutter but happen to have bolt cutter... give it a try.  Cheers!  - R -
