Front Underbody "skirts"
IcyFridge
The only thing that really bothers me about my new '19 Edge is the fact that it has two giant flaps sticking down under the front end (part of the splash shield). Does this serve any function, or should I just lop them off? I don't mind losing a half mpg, but not sure....
With the commute I take to the cabin and the amounts of snow we get, I don't want to be scraping/plowing the ground.
Well. It just looks like little flaps that would only make aerodynamics worse. I think they are for curbs to prevent hitting them. They hang real low. It's not like I'm going to remove the entire underbody splash guard like I did on my previous Jeeps.
Even the F150 has instructions from Ford on how to remove it for when off-roading.
I lopped them off. MPG is the same, and the wheel well is completely enclosed. The underbody is completely covered with no weak spots. I have a feeling it is just to keep the road debris from hitting the front tires to prevent kicking them back up. Kind of like the rear flaps in front of the rear tires.
