LarrysEdge Posted July 25, 2008 Report Share Posted July 25, 2008 I have an 07 Edge SEL Plus AWD. No where in the manual do I find mention of a TPMS. When I cycle through the trip computer check, it never indicates anything about the tire pressure (my Explorer would say "Tire Pressure Ok" or something like that. I purchased in August 07 (1 year ago). Was this maybe one of those famous Ford "Late Availability" deals? -Larry Quote Link to comment Share on other sites More sharing options...
NYEdge Posted July 26, 2008 Report Share Posted July 26, 2008 I don't have my manual in front of me, but I'd check again. I bought my Edge in March 2007 and mine definitely has it. If you drop the pressure in one of your tires by a couple of pounds below the rated psi, you should get the warning after driving a short period. Quote Link to comment Share on other sites More sharing options...
securinu Posted July 27, 2008 Report Share Posted July 27, 2008 it is the tire with an asterix in it in the guages when you first start. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted July 27, 2008 Report Share Posted July 27, 2008 (edited) I have an 07 Edge SEL Plus AWD. No where in the manual do I find mention of a TPMS. When I cycle through the trip computer check, it never indicates anything about the tire pressure (my Explorer would say "Tire Pressure Ok" or something like that. I purchased in August 07 (1 year ago). Was this maybe one of those famous Ford "Late Availability" deals? -Larry Hi Larry. :D Look again in your Owners Manual, in the Index under "Tire Pressure Monitoring System (TPMS)". It is described on page 195 in the online Manual. When you find it you will see that it is not in the scrollable Information Center. It is simply a warning light in the Warning Light Cluster. It looks like a head on cross-section of a tire, with an exclamation point in it. If that warning light illuminates for a second or two when you start the car (when the instrument lights do their system check), you have a working TPMS system. There is a diagram and it is also described in the "Instrument Cluster Warning Lights and Chimes" section. Good luck. :beerchug: Edited July 27, 2008 by bbf2530 Quote Link to comment Share on other sites More sharing options...
