Betsythe2014Edge Posted August 12, 2019 Report Share Posted August 12, 2019 My wife and I have a 2014 Edge. It has 97k miles on it. It has great pressure on the AC system but the AC cuts off and on. If it turns off it stays off. I am thinking it is the low pressure switch. I would like to test the low pressure switch but I can’t locate it. I have tried to explore on google and YouTube too. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 12, 2019 Report Share Posted August 12, 2019 There isn't a low pressure switch that I know of, only a high pressure switch. It is mounted to the compressor-to-condensor discharge line on the condensor side IIRC. Did you check the charge with pro gauges? What was the pressure and the temperature at the time the pressure was measured? Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 25, 2019 Report Share Posted October 25, 2019 On 8/12/2019 at 1:18 AM, Betsythe2014Edge said: My wife and I have a 2014 Edge. It has 97k miles on it. It has great pressure on the AC system but the AC cuts off and on. If it turns off it stays off. I am thinking it is the low pressure switch. I would like to test the low pressure switch but I can’t locate it. I have tried to explore on google and YouTube too. Any help would be appreciated. Expand See the notice at the top of this forum section - you may get a better response if you post in the appropriate section. Quote DO NOT use this forum for Ford Edge discussion. Expand Quote Link to comment Share on other sites More sharing options...
