Woody Posted May 18, 2014 Report Share Posted May 18, 2014 2010 Edge SEL. Yesterday evening while drving in local traffic, temp gauge went to full "H". Pulled over, popped hood and saw some steam in the general area of the Resevoir. Let cool down, added some water and proceeded home. Happened twice more during that 10 mile drive. This morning started troubleshooting. could not find any leaks or cracks, everything was dry. Thought possibly the cap was failing and venting at less than the 16 PSI. Replaced with a new one I had in stock. Idled for 15 minutes, getting it up to temp (right in the middle). Both radiator hose were warm/hot so the T-stat appears to be working. During the idling neither electric fan came on. Went for a 5 mile drive (35-55 MPH) and returned home. Temp stayed in the middle. Let idle for an additional 20 minutes at home and at the end the temp had gond full "H" again!. Once again the fans never engaged. Am I looking at a failed fan controller??? If so, appears to be as cheap/ cheaper to replace the complete assembly. Any thoughts are appreciated. Woody woodruffcrandall@gmail.com Quote Link to comment Share on other sites More sharing options...
akirby Posted May 18, 2014 Report Share Posted May 18, 2014 You can only replace the fans and controller together. The good news is you can get the Dorman part from Amazon for $150 and replace it yourself. I just did mine on Friday. Next time do a simple search before you post - this thread has all the details: http://www.fordedgeforum.com/topic/12731-radiator-fan-assembly-replacement-procedure/ 1 Quote Link to comment Share on other sites More sharing options...
Woody Posted May 18, 2014 Author Report Share Posted May 18, 2014 Thanks for the response. I had already viewed the thread and found the DIY. I was more specifically asking if my description of the issue led more to a controller failure vs the other possible issues (CHT, T-Stat, etc) Thanks, Woody Quote Link to comment Share on other sites More sharing options...
akirby Posted May 18, 2014 Report Share Posted May 18, 2014 If the temp gauge is reading hot and the fans aren't coming on then it's almost certainly the controller. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 19, 2014 Report Share Posted May 19, 2014 Thanks for the response. I had already viewed the thread and found the DIY. I was more specifically asking if my description of the issue led more to a controller failure vs the other possible issues (CHT, T-Stat, etc) Thanks, Woody Since the Fans are not working at all, I suggest you also check the cooling fan fuse/Relay in the Engine compartment fuse box. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 19, 2014 Report Share Posted May 19, 2014 Yep - forgot about the relay(s). There are 2 fuses/relays if you have the towing package, one if not in the power distribution box under the hood. They're labeled in the owner's manual. Quote Link to comment Share on other sites More sharing options...
autom8r Posted May 20, 2014 Report Share Posted May 20, 2014 Hard to diagnose controller failure without "faking" the input to the controller. There is only the CHT sensor. There are no thermostats in the classical sense though I suppose you could rig in a thermostat to control the fans. Both the fans on my old assembly were able to spin with power supplied to their leads. The fan module was toast. As mentioned earlier in this post, it's less expensive to replace the whole assembly than to replace just the module. I'm sure it's just a cheesy transistor that's failed in the module. I haven't had a chance to tear it down and look at it, but it seems like a great business for a kid with soldering skills that needs a part time job if that's what it is. Here is an excerpt from the shop manual showing the wiring. An output from the controller goes to the fan control module and the fan controller spools up the fans. The tow package fan module is a two channel version of the non-tow package, but the two cannot be used interchangeably. Good Luck. Ford Edge Cooling Fan Wiring.pdf Quote Link to comment Share on other sites More sharing options...
Woody Posted May 20, 2014 Author Report Share Posted May 20, 2014 Replaced the Fan Assembly (w/controller) and that solved the problem. Immediately on start and A/C turned on both fans started on low. Idled for 20 minutes, drove for 30, idled again for 20. Temp stayed just shy of top dead center. Obviously the controller failed. All is well. Thanks to all for insight and recommendations. Woody 1 Quote Link to comment Share on other sites More sharing options...
f150bft Posted June 16, 2014 Report Share Posted June 16, 2014 Would the fans not come on when the A/C was turned on? I thought that the A/C would over-ride any controller/thermostat and turn on the fans? Quote Link to comment Share on other sites More sharing options...
akirby Posted June 16, 2014 Report Share Posted June 16, 2014 There is no direct connection to the fans. The PCM talks to the controller that's built into the fan module and the module turns on the fans as needed. Quote Link to comment Share on other sites More sharing options...
staylor Posted August 5, 2019 Report Share Posted August 5, 2019 My edge is overheating. I just bought the control module and I see it and unplugged it to check connections but my question is how do I replace it? The only videos I’m finding is how to replace fan and I’m just trying to switch out module. Thanks Quote Link to comment Share on other sites More sharing options...
staylor Posted August 5, 2019 Report Share Posted August 5, 2019 (edited) Can someone tell me where I can find a DIY video on how to replace module only? Every time I look it shows the fan replacement not the module. Thanks I am desperate. Ford edge 2010 SEL tow pkg Edited August 5, 2019 by staylor Quote Link to comment Share on other sites More sharing options...
akirby Posted August 5, 2019 Report Share Posted August 5, 2019 That's because the fan and module come together and should be replaced together. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted August 5, 2019 Report Share Posted August 5, 2019 And if that's a Dorman part throw it away or return it and get a Motorcraft replacement unit. Many a Dorman has been DOA. Quote Link to comment Share on other sites More sharing options...
