Hesitation or jerking
Chris B
Hello.I just recently purchased a 2007 Edge SEL AWD from a dealer.It has 198k mi.The problem with it is in lower rpm it will hesitate or jerk.We drove 200 miles last weekend and at a point the service light(wrench) came on and the ac cut out.Has anyone else had this issue?I just saw on here the fuel filter is internal and can’t be changed.Any suggestions on what to look out for would be appreciated.
Welcome!  Service history?  Fluid changed at what mileage, this is very important.  Could be the fluid was let go too long.   Since you got a CEL, check for codes set in the PCM.  I suspect it will say either a TSS or OSS sensor related issue.  Hopefully nothing deeper like a clutch.  There is a possibility of a cracked tone ring as well.  Getting to be that age.
The most likely result:  needs new TSS/OSS sensors (always repair in pairs), new fluid, and possibly a reset of the transmission adaptive tables.
