bill48nj1 Posted July 27, 2019 Report Share Posted July 27, 2019 Hi I just got a 2011 Edge SEL 3.5L FWD. I have a 2GB USB flash drive with only mp3s on it. It's recognized when plugged in and works fine. My question is if I leave this music USB plugged in with ignition off and key out, is there any draw on the battery? Searching the web shows both yes and no for battery drainage. Thanks for your help. Bill NJ Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted July 27, 2019 Report Share Posted July 27, 2019 2 hours ago, bill48nj1 said: My question is if I leave this music USB plugged in with ignition off and key out, is there any draw on the battery? Hi Bill, You're safe leaving your USB drive plugged in. Some Edge models have a power port delay that can be adjusted by the user so, depending on your model and settings (a previous owner 'could' have set the power ports to be on at all times but not likely) the device might stay on for a short time but the current draw is minuscule. To prove this, plug anything with a power indicator light into the port. Turn the Edge off and watch the light. It'll either turn off immediately or soon after shutdown. Cheers! 1 Quote Link to comment Share on other sites More sharing options...
bill48nj1 Posted July 28, 2019 Author Report Share Posted July 28, 2019 Got it. Thanks for the quick response. Bill Quote Link to comment Share on other sites More sharing options...
