Kross77 Posted July 26, 2019 Report Share Posted July 26, 2019 (edited) Was on way to work and my edge kinda jolted, couldnt drive past 5mph..like transmission wouldnt engage drove about 1 mile..then turned off restarted and was normal again. Any help would be great...thx Has 112000 miles, have had zero problems beside wheel bearing. Have done just normal maintenance, oil, brakes, etc. Check engine light come on couple times was reading catalytic converter. 2013 ford edge sport. Edited July 26, 2019 by Kross77 More info 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted July 26, 2019 Report Share Posted July 26, 2019 Could be a ghost in the machine, or there could be an underlying issue. First thing I would check is my transmission fluid level. Secondly I would check for any DTC codes with an OBD scanner/ reader. You should state the year, model and mileage of your edge. Also state what routine maintenance has been done. One of the more knowledgable members can provide deeper insight once you provide some info. Quote Link to comment Share on other sites More sharing options...
Kross77 Posted July 26, 2019 Author Report Share Posted July 26, 2019 Ok thank you Quote Link to comment Share on other sites More sharing options...
