paker Posted July 24, 2019 Report Share Posted July 24, 2019 I watched MacT's video on the subject. There seems to be sufficient room to remove the ball joint without removing the entire lower control arm. I wonder if anyone has done it. Thank you. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 25, 2019 Report Share Posted July 25, 2019 You will find that such a fix will not last long. The ball joint - control arm socket has worn already, so the fitment will not be as goodntight as a brand new LCA. 1 Quote Link to comment Share on other sites More sharing options...
paker Posted July 25, 2019 Author Report Share Posted July 25, 2019 (edited) I read about the ball joint socket getting loose on repeated ball joint replacements in pickups. But I have never experienced (limited experience based on 4 or 5 cars I have owned) the socket being loose after the original ball joint was removed. May I ask if this is your first hand experience with Edge? Edited July 25, 2019 by paker Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 26, 2019 Report Share Posted July 26, 2019 No it is not first hand for me, but based on several owner testimonials. For the Edge, generally, with a few exceptions, you are better off sticking with Motorcraft/Ford parts rather than aftermarket to retain OEM quality operation. Aftermarket parts either do not fit well, or do not last long. If you can find a Motorcraft branded ball joint, or are willing to do the job again, give it a go. Keep us updated either way Quote Link to comment Share on other sites More sharing options...
paker Posted July 27, 2019 Author Report Share Posted July 27, 2019 (edited) Thank you for sharing the information. Edited July 27, 2019 by paker Quote Link to comment Share on other sites More sharing options...
