Lower ball joint replacement
I read about the ball joint socket getting loose on repeated ball joint replacements in pickups. But I have never experienced (limited experience based on 4 or 5 cars I have owned) the socket being loose after the original ball joint was removed. May I ask if this is your first hand experience with Edge?
Edited by paker
No it is not first hand for me, but based on several owner testimonials.  For the Edge, generally, with a few exceptions, you are better off sticking with Motorcraft/Ford parts rather than aftermarket to retain OEM quality operation.  Aftermarket parts either do not fit well, or do not last long.  If you can find a Motorcraft branded ball joint, or are willing to do the job again, give it a go.  Keep us updated either way :)
