Squeal and hiss from brake pedal
I have a 2013 Edge with 96000 miles and yesterday as I was coming to a stop there was a decent sounding squeal coming from my brake pedal when it was fully depressed. It almost sounded like a warning sound. Also when idling at a stop, there is slight hiss sound coming from there as well. I did find a service bulletin that may be in conjunction with this. The bulletin # is 13N02 and it explains it is a brake booster and is covered for 10 years or 150,000 miles. It also explains that it is the result of a tear in the diaphragm. Has anyone had this issue and is it covered by Ford?
  • DelSil changed the title to Squeal and hiss from brake pedal
15 hours ago, WWWPerfA_ZN0W said:
If you are past 150K miles, no.  Otherwise, yes.
Bayshore Ford in Delaware, where I have the vehicle, told me my Edge is not covered in this CSP #. They did mention though this is the exact issue this bulletin covers so I opened a case # with Ford to get this taken care of by them. the repair will cost me $1100 according to Bayshore
