DelSil Posted July 18, 2019 Report Share Posted July 18, 2019 I have a 2013 Edge with 96000 miles and yesterday as I was coming to a stop there was a decent sounding squeal coming from my brake pedal when it was fully depressed. It almost sounded like a warning sound. Also when idling at a stop, there is slight hiss sound coming from there as well. I did find a service bulletin that may be in conjunction with this. The bulletin # is 13N02 and it explains it is a brake booster and is covered for 10 years or 150,000 miles. It also explains that it is the result of a tear in the diaphragm. Has anyone had this issue and is it covered by Ford? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 18, 2019 Report Share Posted July 18, 2019 If you are past 150K miles, no. Otherwise, yes. Quote Link to comment Share on other sites More sharing options...
DelSil Posted July 19, 2019 Author Report Share Posted July 19, 2019 15 hours ago, WWWPerfA_ZN0W said: If you are past 150K miles, no. Otherwise, yes. Bayshore Ford in Delaware, where I have the vehicle, told me my Edge is not covered in this CSP #. They did mention though this is the exact issue this bulletin covers so I opened a case # with Ford to get this taken care of by them. the repair will cost me $1100 according to Bayshore 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 19, 2019 Report Share Posted July 19, 2019 Will/should cost FAR less than that. Any competent repair facility can take care of it for under $600. Let's hope Ford will assist tho. Quote Link to comment Share on other sites More sharing options...
