Fans not working
JHoude
Hello,
I have a 2011 Ford Edge SEL and the engine fans do not come on.
i have tested the fans and they are good.
I have replaced the FCM and still nothing.
There is power going into the FCM.
Put a scope on the control signal and I see nothing.
Where does the signal come from and any ideas why it would not be active?
One would have thought that a missing control signal would result in the fans going to full speed.......
Edited by JHoude
Solution found
Found the problem by pure luck.
When I scoped the signal there was nothing so today, I figure it possibly needed to be connected to the FCM to have it pulled up.
When I pulled the cable to get it off of the FCM, the control wire came apart about 1/2" from the connector.
Scoped the end of the cable and there was something so I soldered in an extension piece and Voila. Fixed!
Possibly a vibration point on the cable?
