Check charging system 2012
mississippiedge
ok, so I've read a few threads but really with no luck, had a check charging system come on intermittently when driving past 40mph, car was charging at 12.5 and down to 11.5 when revved to 2k
replaced the alternator and now car is running rough (I assume ecm needs to relearn since car sat for a while disconnected) anywho after replacing alternator car still has check charging system light stays on 100% of the time
Kind of at a loss of words and dont know what to check next. battery is abt 1.5 years old, had a bad battery on it before but never caused poor charging issues.
Ideas to check next before I dump 330 dollars on a new battery? (car audio battery) could I have had the luck of buying a bad alternator?
Something is definitely drawing and will eventually kill the battery. If you have a OBD reader you can check to see if you have any DTCs that are not portrayed as a check engine light.
Another option would be go to go to autozone/ advanced auto or someplace similar and have them run a check on your charging system.  At least at that rate you have some sort of idea of what your next steps should be.
You didn't mention it but is your alternator new or rebuilt? Is it Ford or aftermarket? Some aftermarket parts fail to perform as expected compared to official ford parts.  Not stating this is your problem but its something to consider.
Double check your terminals etc, alarm connections etc just tossing ideas out there. I had what I thought was a good terminal kill a battery on a expedition once.
If your battery is 1.5 years old it should still be under warranty.
Good Luck!
Edited by onyxbfly
  • 3 years later...
