calling_john_galt Posted June 26, 2019 Report Share Posted June 26, 2019 I have a 2015 Edge SE with the 3.5L engine, 56k miles. I have an intermittent problem where while driving at operating temperature, the following happens: 1. Transmission slips out of gear. It tries to get back into gear, resulting in lurching. Engine continues to run. 2. The gear indicator in the instrument cluster does not display the gear the shifter is in (see attached pic, note the tach shows the car is running, just no gear indicated.) 3. The rear camera activates. The only solution is to stop the car, put it into park (still without a gear indicator displaying on the instrument cluster), stop the engine and start over. Until recently this has resolved the problem. Most recently, the problem immediately recurred. On the 8th try, it cleared up. No codes captured, no error messages displayed. Have never seen the "Shift-to-park" error since we've owned the car. Been to the dealer twice, but of course they are unable to reproduce. They did confirm that there were no codes of any kind captured. Any suggestions on things to look at? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
calling_john_galt Posted June 28, 2019 Author Report Share Posted June 28, 2019 It finally happened while I was driving. I first noticed the rear camera was on while at highway speeds. Then I noticed the gear indicator. The transmission made no attempt to go back into gear-- it just coasted about 3-4 seconds. Then the camera turned off and it went back into gear as if nothing happened. Quote Link to comment Share on other sites More sharing options...
Will W Posted November 24, 2024 Report Share Posted November 24, 2024 This happens off and on with our 2015 Ford Edge..... very unsafe if will happen at any speed. I have videos of it going in and our of gear. Wish Ford would send a computer update and/or recall for this before someone get in a serious accident or killed. Quote Link to comment Share on other sites More sharing options...
1004ron Posted November 24, 2024 Report Share Posted November 24, 2024 1 minute ago, Will W said: This happens off and on with our 2015 Ford Edge..... very unsafe if will happen at any speed. I have videos of it going in and our of gear. Wish Ford would send a computer update and/or recall for this before someone get in a serious accident or killed. Welcome. What's the mileage and service history? Have you done any maintenance on the transmission, such as a fluid replacement? Did you take it to Ford for them to diagnose it and quote on repairs if needed? Quote Link to comment Share on other sites More sharing options...
