Help! [2017 2.0L] Remove brake booster hose @ manifold
I'm trying to remove the intake manifold to access the fuel injectors on my 2017 2.0L Ecoboost. (the next step in my quest to diagnose a repeated cylinder #2 misfire). The brake booster hose runs into the right side of the manifold & seems to require a special tool for removal, or at least I think so. The coupler is red, round and smooth (there's no clips). Does anyone have experience with this hose/coupler and what it takes to remove it? I've searched this forum and the internet and can't seem to find any mention of it.  thanks!
I removed this when i did my catch can install.  I believe  that if you push the pipe to the intake manifold & use something to hold the red ring on the intake manifold, it should pop right off.  Doubt this will help, but here's part of my catch can install:
https://www.fordedgeforum.com/topic/22063-oil-catch-can-on-the-20l-ecoboost/?do=findComment&comment=165970
