Code P0340 and P0344
Ford_Owner
Hi everyone,
Recently, I replaced the cover gasket of the bank 1 and performed the engine oil changed (5w20 as described on the owner manual), and when I started the car I got two codes P0340 and P0344 (using my ODB Scanner).  Does anyone know where the camshaft position sensor is located and how to fix the problem?
Thanks!
P.S. Ford Edge 2014 Limited AWD
