handfiler Posted May 15, 2020 Report Share Posted May 15, 2020 I think 87 octane is the limiting factor to having meaningful gains with a tune. 91 and up is where the gains are more noticeable. You should reach out to Torrie with regard to tuning your Edge. I spoke with him at length about tuning my Lincoln. He seems like a stand up guy and knows this platform inside out. Quote Link to comment Share on other sites More sharing options...
Xtra Posted May 16, 2020 Report Share Posted May 16, 2020 On 5/15/2020 at 6:01 AM, dajo2012 said: Does the tune give more accel say up to 30mph? My ST is less than impressive off the line. Can a person get the 87 tune and make an improvement here. I have the unleashed tune in my F150, currently using the 87 tune and can't really tell much difference but is feels like it is quicker that the ST. In a turbo car the fuel you use is important. The higher the octane the more power you can make without knocking. If you have an ST try 91 or 93 fuel you should feel a positive difference over 87. A LMS performance tune with 93 will make a ton more power and accelerate way faster than running on 87 with no tune. 1 Quote Link to comment Share on other sites More sharing options...
txaggie Posted May 20, 2020 Report Share Posted May 20, 2020 On 5/14/2020 at 5:37 PM, Xtra said: It might have a bit firmer shift, other than that driveability is not affected. If the shifts are to firm they can be softened, no problem. The LMS tune is great for every day driving. Does the tune disable or reset the FORScan modifications? Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 20, 2020 Report Share Posted May 20, 2020 3 hours ago, txaggie said: Does the tune disable or reset the FORScan modifications? No. 1 Quote Link to comment Share on other sites More sharing options...
txaggie Posted May 21, 2020 Report Share Posted May 21, 2020 Well, ordered the Livernois system today, can't wait to get it! ? Quote Link to comment Share on other sites More sharing options...
svlaming Posted January 22, 2021 Report Share Posted January 22, 2021 Question on this topic, does adding the tune effect the shift point in normal driving mode or just in "Sport Mode"? Quote Link to comment Share on other sites More sharing options...
Kindafastst Posted July 31, 2021 Report Share Posted July 31, 2021 On 6/22/2019 at 7:40 AM, jamie1073 said: Just ordered my Livernois MyCalibrator Touch on Thursday. Should be here Monday to get me started on my ST tune. I am going to leave the rest stock for now since it is a lease and get at least a 91 and 93 tune and maybe a tow tune since you get 4. I have recorded a 5.8 0-60 times using my wifi OBDII adapter and the Car Scanner App on my iPhone, it is around 5.81. Did basically the same in both normal and sport mode and trying to brake torque. I will test again before I update the tune and then test on the 91 and again on the 93 tune files. No one seems to post any numbers so I figure I will do that. I know it does not tell us the power increase but I feel it is more useful since it will show what they can do with the trans as well as increased power to hopefully net a nice gain. I picked them since I like the increased mid range torque on the dyno they have posted and the fact they will give you up to 4 tunes that you can change at anytime, like if there is a new revision, for free. Anyway we shall see I guess. Hey was wondering if you ever ran some 0-60’swith the LMS 93 tune. Having a hard time deciding if I should do unleashed, lms, or one of the others. 1 Quote Link to comment Share on other sites More sharing options...
handfiler Posted July 31, 2021 Report Share Posted July 31, 2021 1 hour ago, Kindafastst said: Hey was wondering if you ever ran some 0-60’swith the LMS 93 tune. Having a hard time deciding if I should do unleashed, lms, or one of the others. Not sure if you are aware, your avatar is upside down. 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted July 31, 2021 Report Share Posted July 31, 2021 (edited) 14 hours ago, handfiler said: Not sure if you are aware, your avatar is upside down. His ST is so fast that it flipped his avatar! That's what happens when you put the s(POR)t back into the ST!! Edited July 31, 2021 by onyxbfly 2 Quote Link to comment Share on other sites More sharing options...
Pablo Sanz Posted October 7, 2024 Report Share Posted October 7, 2024 (edited) Hi, I whant to update this topic... i have 2021 edge st, livernois E30 tune... 107F 1145ft over sea DA4954ft Edited October 7, 2024 by Pablo Sanz Quote Link to comment Share on other sites More sharing options...
rlarson69 Posted April 7 Report Share Posted April 7 (edited) 2020 Edge ST with the LMS 93 only launched a few times, and the best 0-60 out of 5 runs was 5.19 and 1/4 13.70 @ 100. Just updated to the next level tune from LMS and haven't tried any runs yet K&N dop in filter Larger intercooler LMS 93 tune and cooler spark plugs Rambo 2.5" Cold side charge tube Edited April 7 by rlarson69 1 Quote Link to comment Share on other sites More sharing options...
dolsen Posted April 8 Report Share Posted April 8 Does LMS allow you to datalog for revisions/fine tuning? 1 Quote Link to comment Share on other sites More sharing options...
rlarson69 Posted April 9 Report Share Posted April 9 Does LMS allow you to datalog for revisions/fine tuning? They do not. I asked about this, and the only reason they view logs is if there are issues with how the engine runs on the tune. 2 Quote Link to comment Share on other sites More sharing options...
dolsen Posted April 9 Report Share Posted April 9 (edited) 10 hours ago, rlarson69 said: Does LMS allow you to datalog for revisions/fine tuning? They do not. I asked about this, and the only reason they view logs is if there are issues with how the engine runs on the tune. BOOOOO... thanks for the info though 😀 Honestly I'm a bit underwhelmed by the 93 tune from Livernois. My stock Explorer ST is still faster (or at least it still feels faster 🤷♂️) Edited April 9 by dolsen 1 Quote Link to comment Share on other sites More sharing options...
rlarson69 Posted April 9 Report Share Posted April 9 2 hours ago, dolsen said: BOOOOO... thanks for the info though 😀 Honestly I'm a bit underwhelmed by the 93 tune from Livernois. My stock Explorer ST is still faster (or at least it still feels faster 🤷♂️) After only 3 months of owning the Edge ST I have been looking at the Explorer ST Quote Link to comment Share on other sites More sharing options...
