kevman991 Posted June 14, 2019 Report Share Posted June 14, 2019 (edited) Hi guys , I noticed that a lot of you guys have had this mysterious sound in front of your trucks and that nobody can't find, well I doug in deep this afternoon and found the problem for most of your mysterious aggravating sound in front cradle: if you have the original lower control arm ( because Ford has a new upgraded one now) the soldering around the bracket of your links bars on the control arm rusts , breaks , separate and makes an aggravating clunking sound at low speed!! See pic , so just have to purchase and install the new upgraded one and no more noise or whatever sounds in the front of your Edge!! Edited June 14, 2019 by kevman991 Correction 2 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 15, 2019 Report Share Posted June 15, 2019 I also live in a rust-belt but haven't had a weld problem like your pics show. That's serious rust ya got there and is the reason I keep mine under-coated. I did have both sway bar links go bad and replace them with Moogs. My Edge is also a 2011 with around 100,000 miles. 1 Quote Link to comment Share on other sites More sharing options...
kevman991 Posted July 6, 2019 Author Report Share Posted July 6, 2019 On 6/15/2019 at 8:54 AM, fishx65 said: I also live in a rust-belt but haven't had a weld problem like your pics show. That's serious rust ya got there and is the reason I keep mine under-coated. I did have both sway bar links go bad and replace them with Moogs. My Edge is also a 2011 with around 100,000 miles. Yeah! Québec is nasty ? I got mine anti-rust grease , not oil, I just did not do the tables..I got 164km?? Quote Link to comment Share on other sites More sharing options...
