tallguy Posted June 11, 2019 Report Share Posted June 11, 2019 I just purchased a 2019 edge SEL fwd. Does anyone know how to shift gear under "S" mode? I couldn't find the "-" & "+" Paddle shifters on the steel wheel? thanks, Quote Link to comment Share on other sites More sharing options...
akirby Posted June 12, 2019 Report Share Posted June 12, 2019 For 2019 you only get Selectshift with AWD. No idea why they did that but yours doesn't have selectshift thus no paddles. 1 Quote Link to comment Share on other sites More sharing options...
tallguy Posted June 13, 2019 Author Report Share Posted June 13, 2019 thanks. So that means I couldn't switch to a lower gear when driving on a long downhill or uphill? Quote Link to comment Share on other sites More sharing options...
akirby Posted June 13, 2019 Report Share Posted June 13, 2019 What options do you have on the transmission gear selector - does it still have S mode? If so then that will help a little but you won't be able to force it to stay in 1st or 2nd gear. Also - double check to see if you have +/- buttons on the shifter. Quote Link to comment Share on other sites More sharing options...
tallguy Posted June 13, 2019 Author Report Share Posted June 13, 2019 It has S mode but no +/- buttons. Quote Link to comment Share on other sites More sharing options...
akirby Posted June 13, 2019 Report Share Posted June 13, 2019 1 hour ago, tallguy said: It has S mode but no +/- buttons. That's all you can do then. It's possible the software and connections are still there if you wanted to add the paddles yourself. Not sure what that involves partswise and there is no guarantee it will work but it's worked in the past on other vehicles. Quote Link to comment Share on other sites More sharing options...
