Sage Posted June 8, 2019 Report Share Posted June 8, 2019 I had installed the LMS 93 octane, V3 tune a bit ago. As can happen, I started to wonder if it was really making a difference. A couple of weeks ago, I re-installed the stock tune for a couple of weeks. I had two appointments a couple of weeks apart to get the TSB done on the trans and than a week later the adaptive headlight software done. I re-installed the 93 tune yesterday and took a drive today, it does make a difference. Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 8, 2019 Report Share Posted June 8, 2019 Doesn't the TSB involve flashing the PCM? Shouldn't you get an updated tune from LMS and stored the new stock tune? I am not really sure how it is supposed to work, but that was my understanding. Quote Link to comment Share on other sites More sharing options...
Sage Posted June 8, 2019 Author Report Share Posted June 8, 2019 (edited) 2 hours ago, omar302 said: Doesn't the TSB involve flashing the PCM? Shouldn't you get an updated tune from LMS and stored the new stock tune? I am not really sure how it is supposed to work, but that was my understanding. Not sure, I thought the LMS tune worked with the ECM. I will give them a call and ask. I will update what I find here. Edited June 8, 2019 by Sage Quote Link to comment Share on other sites More sharing options...
bobyellow Posted June 8, 2019 Report Share Posted June 8, 2019 Interesting. When I had a PCM updated in Feb, prior to the official TSB, I had a new strategy code... my LMS wouldn't even connect. I'm guessing that the cloud now 'knows' about the new PCM. I would recommend reaching out to them. Hopefully you saved the stock after the PCM update! Otherwise you might be reverting to the old 'bad' shift points the next time you revert to stock. Quote Link to comment Share on other sites More sharing options...
037 Posted June 9, 2019 Report Share Posted June 9, 2019 A bit boring reading how the tune "does" make a difference. In my experience v3 took a 14 second car and made it a 12 second car. I would say crazy unbelievable improvement is the word. That's on 93 octane. 1 Quote Link to comment Share on other sites More sharing options...
Sage Posted June 9, 2019 Author Report Share Posted June 9, 2019 8 hours ago, 037 said: A bit boring reading how the tune "does" make a difference. In my experience v3 took a 14 second car and made it a 12 second car. I would say crazy unbelievable improvement is the word. That's on 93 octane. It is unfortunate that my post bores you. I recommend when you see a post that I make, just skip over it, as it is not my intention to bore anyone. 3 Quote Link to comment Share on other sites More sharing options...
037 Posted June 10, 2019 Report Share Posted June 10, 2019 I was just saying you had a very muted reaction to what in my experience was a huge deal. Don't lose any sleep over my comment, it's not meant to offend. 1 Quote Link to comment Share on other sites More sharing options...
Sage Posted June 10, 2019 Author Report Share Posted June 10, 2019 On 6/8/2019 at 7:03 PM, bobyellow said: Interesting. When I had a PCM updated in Feb, prior to the official TSB, I had a new strategy code... my LMS wouldn't even connect. I'm guessing that the cloud now 'knows' about the new PCM. I would recommend reaching out to them. Hopefully you saved the stock after the PCM update! Otherwise you might be reverting to the old 'bad' shift points the next time you revert to stock. I gave LMS a call and was told, like what happened to you, if the strategy code changed on the Edge, the LMS device will not connect. Looks like I lucked out this time and will be more attentive next time. Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 11, 2019 Report Share Posted June 11, 2019 6 hours ago, Sage said: I gave LMS a call and was told, like what happened to you, if the strategy code changed on the Edge, the LMS device will not connect. Looks like I lucked out this time and will be more attentive next time. Or the dealership did not really update the PCM. On many occasions when my dealer had told me they "updated" a module I found out they simply "reset" it or just reloaded the factory "As Built Data". Quote Link to comment Share on other sites More sharing options...
Sage Posted June 11, 2019 Author Report Share Posted June 11, 2019 8 hours ago, omar302 said: Or the dealership did not really update the PCM. On many occasions when my dealer had told me they "updated" a module I found out they simply "reset" it or just reloaded the factory "As Built Data". I thought of that as well, but not sure how to double check that. Quote Link to comment Share on other sites More sharing options...
bobyellow Posted June 11, 2019 Report Share Posted June 11, 2019 On the tuner>> Vehicle Info Code: Orig: CNDK2F3 New: CNDM1A4.H32 SW Orig: K2GA-14C204-ARK New: K2GA-14C204-DGA Quote Link to comment Share on other sites More sharing options...
