water in hatch after washing it
Lincoln81
hey guys, got around to wash my new to me 2015 edge and when opening my hatch I noticed a water noise, moved the hatch back and forth and a bit of water came out of the latch area, then noticed the 2 rubber plugs/stoppers on either side and pulled them out and a few gallons of water came out...
Where is the water getting in from? Is this normal? Bad seal somewhere?
worried about winter going through a carwash and it freezing causing premature rust
thanks
Mike, I did not notice the rectangular drainage holes but I will take a look.
I did investigate over the weekend, took the back plastic off, got inside while my son hosed the back of the edge and the water was coming in from the handle. I removed the handled and dried it, dried the outside of it and put some silicon on it, put it back on. let it dry and then tried to hose and no more water. While I was in there I put some rust control in a can to help keep it all good
cheers
  • Like 3
