2017 V rated 20” tires
nc_edge
V and H are speed ratings . For a high milage tire look at the UTQG number . 100 is the standard control tire used for life of treadwear. If the UTQG number is 300 on the tire you are looking at then that tire will have treadwear 3 times the control tire. 500 means the tire will have 5 times the treadwear of the control tire. So to make it simple get a tire with the highest UTQG number you can for maximum tread life . 300 is a good solid number some tires get 650 ratings . for more info on UTQG look here   https://info.kaltire.com/utqg-ratings/
