nc_edge Posted June 1, 2019 Report Share Posted June 1, 2019 My 2017 titanium has the pirelli 245/50/20 v rated tires. I am certain earlier year edges did not have v rated tires. Has as anyone had experience with dropping down to H rated tires? I want to buy tires that will last longer. Quote Link to comment Share on other sites More sharing options...
Xtra Posted June 4, 2019 Report Share Posted June 4, 2019 V and H are speed ratings . For a high milage tire look at the UTQG number . 100 is the standard control tire used for life of treadwear. If the UTQG number is 300 on the tire you are looking at then that tire will have treadwear 3 times the control tire. 500 means the tire will have 5 times the treadwear of the control tire. So to make it simple get a tire with the highest UTQG number you can for maximum tread life . 300 is a good solid number some tires get 650 ratings . for more info on UTQG look here https://info.kaltire.com/utqg-ratings/ Quote Link to comment Share on other sites More sharing options...
