ty23 Posted May 26, 2019 Report Share Posted May 26, 2019 New guy here looking for some help. I have a 2008 edge fwd and I've been having a shaking/vibrating issue in the front end. If I'm driving 40mph or over and have to steer slightly to the right, I get this nasty shaking. It almost sounds and feels like my tires are wobbling hardcore. But if I steer it hard to the right it doesn't do it. Only if I turn slightly to the right. Any ideas on what could be causing this? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 26, 2019 Report Share Posted May 26, 2019 Welcome! How many miles on your Edge, and do you have chrome clad wheels? First thing to eliminate is tires & wheels. Examine carefully for lost wheel weights, damaged/bent/cracked wheel, improper lug nut torque, and tire wear/tread separation. If all looks good, rotate tires front to rear and see if the shaking continues abated. Second, inspect the suspension and steering for worn components, specifically bushings. Control arms/ball joints, tie rod ends, sway bar links/bushings, etc. Quote Link to comment Share on other sites More sharing options...
Sage Posted May 26, 2019 Report Share Posted May 26, 2019 Welcome, sorry I cannot help on your situation. Quote Link to comment Share on other sites More sharing options...
