jeff30189 Posted May 19, 2019 Report Share Posted May 19, 2019 I see conflicting information on various websites. What is the OE wheel width for the 20" rims/tires? I've seen both 8" and 9" - makes a big difference when looking at replacement tires. Second and related question that will depend on the answer to the above.... what is the widest profile tire that will safely fit onto the OE wheel size? If it's an 8" rim you probably can't go beyond 255, but if it's a 9" rim then 265 is definitely doable. Thanks to anyone who can provide an accurate answer. Quote Link to comment Share on other sites More sharing options...
1004ron Posted May 19, 2019 Report Share Posted May 19, 2019 The 21" wheels are a factory option on this model, with the standard being 20", so post a photo of your wheels and we'll be able to tell whether you have 20 or 21". Quote Link to comment Share on other sites More sharing options...
jeff30189 Posted May 20, 2019 Author Report Share Posted May 20, 2019 I have 20" wheels - that's the only part for which I am certain. The question was whether the wheels were 8" width or 9" width on the OE for a 2015 Ford Edge Sport AWD. Thanks! I'd like to get wider (265 vs. 245) tires but if it's only an 8" wheel width then that's not going to work. Quote Link to comment Share on other sites More sharing options...
lightning4eva Posted May 28, 2019 Report Share Posted May 28, 2019 20s are 8” https://www.wheel-size.com/ Quote Link to comment Share on other sites More sharing options...
Special_K Posted June 5, 2019 Report Share Posted June 5, 2019 On 5/20/2019 at 8:22 AM, jeff30189 said: I have 20" wheels - that's the only part for which I am certain. The question was whether the wheels were 8" width or 9" width on the OE for a 2015 Ford Edge Sport AWD. Thanks! I'd like to get wider (265 vs. 245) tires but if it's only an 8" wheel width then that's not going to work. @snmjimhas a nice set of 20's forsale if you're still looking. Quote Link to comment Share on other sites More sharing options...
