BAYLENSMAN Posted May 15, 2019 Report Share Posted May 15, 2019 So all of a sudden the passenger side defroster just blows air. not hot not cold just air. The drivers side works fine. I am assuming that there is a duct not opening correctly. If its pushing air but not getting warm. does any one have any idea? or a diagram of the vents and were the ducts flappers and air motors are? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 15, 2019 Report Share Posted May 15, 2019 Only in defrost or are there problems in other modes as well - heat, ac, etc. If only in defrost, you may have mode door problems, very rare, but it happens. Manual climate control or dual zone/electronic? Quote Link to comment Share on other sites More sharing options...
BAYLENSMAN Posted June 3, 2019 Author Report Share Posted June 3, 2019 On 5/15/2019 at 6:51 AM, WWWPerfA_ZN0W said: Only in defrost or are there problems in other modes as well - heat, ac, etc. If only in defrost, you may have mode door problems, very rare, but it happens. Manual climate control or dual zone/electronic? It appears to be only the defrost on the passenger side. driver's has warm air passenger just air volume seems about the same just the temparture is different, which is weird because from the few poor quality pics i've gotten of the dash layout both side appear to feed from the same outlet? i do have the dual zone electronic climate control. Quote Link to comment Share on other sites More sharing options...
