flymore Posted May 13, 2019 Report Share Posted May 13, 2019 I'm enjoying my Edge, but one thing I really miss from my Chevy is the source button on the steering wheel. The source button allowed me to switch from AM, FM, CD, Siris XM and alternate input. The only way to switch sources is to activate the voice command or take my hand from the wheel and eyes off the road? This is a bit annoying with other people in the car and you're talking to them. Quote Link to comment Share on other sites More sharing options...
1004ron Posted May 13, 2019 Report Share Posted May 13, 2019 My buttons on the top right of the steering is what I use to switch source. 1 Quote Link to comment Share on other sites More sharing options...
benk016 Posted May 14, 2019 Report Share Posted May 14, 2019 You can change the input with the 4 way arrows on the right side of the steering wheel. Its not as easy as pushing one button until you get to the source you want, but is doable. When your right cluster screen is showing the current channel or song, press right, and it will give you a list of sources. Quote Link to comment Share on other sites More sharing options...
flymore Posted May 14, 2019 Author Report Share Posted May 14, 2019 Thanks, I'll keep playing around with it. 1 Quote Link to comment Share on other sites More sharing options...
Fingernip Posted May 30, 2019 Report Share Posted May 30, 2019 I also miss the source button from my 2011. The right menu works but requires more concentration. Quote Link to comment Share on other sites More sharing options...
flymore Posted June 15, 2019 Author Report Share Posted June 15, 2019 Three annoyances, 1. No source button. Using the menu or keypad distracts you from driving. 2. You have to turn the cruise on every single time you start the car. My previous car had a button that locked in the on setting. 3. Dual climate control has to be chosen every time you start the car - why doesn't it just leave dual climate on! Quote Link to comment Share on other sites More sharing options...
akirby Posted June 16, 2019 Report Share Posted June 16, 2019 1 hour ago, flymore said: Three annoyances, 1. No source button. Using the menu or keypad distracts you from driving. 2. You have to turn the cruise on every single time you start the car. My previous car had a button that locked in the on setting. 3. Dual climate control has to be chosen every time you start the car - why doesn't it just leave dual climate on! A button would be better but you can always use voice commands to change sources. Almost all new vehicles default cruise control to off for safety. What exactly are you trying to do with the climate control? Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted June 16, 2019 Report Share Posted June 16, 2019 I definitely agree that a source button would be helpful but with all of the available sources you would still need to do navigate to your preferred source. You can use the buttons on the right side of the steering wheel to interact with the right side IPC and navigate your sources. Or you can hit the sound button and that will pull you out of android auto/ car play and you can interact with your sources that way. You can set the cruise control to your preferred speed. You just have to start it and stop it manually. I am not aware of any car that engages cruise control as soon as you start your car. Climate control is set to resume the last setting. If you have dual climate on it will be on when you star your car. The only way that changes is if the passenger decides to make a change to their temp etc. If you do not go back into climate control to set it back to dual then it will resume the individual settings until you switch it back to dual. HTH Quote Link to comment Share on other sites More sharing options...
flymore Posted June 29, 2019 Author Report Share Posted June 29, 2019 On 6/15/2019 at 8:49 PM, akirby said: A button would be better but you can always use voice commands to change sources. Almost all new vehicles default cruise control to off for safety. What exactly are you trying to do with the climate control? With the climate control I have to go in menus and turn on DUAL, so my wife can have a different temperature on her side of the car than mine. Would like to have DUAL on by default, there is no safety issue here with DUAL climate. I don't see the risk with leaving the cruise on, it doesn't engage unless you press SET and the car is moving over 25mph. So how is having the cruise off safer? Yes I can change the source with a voice command, I have to hold down the voice command button, wait for it to stop speaking then say what source I want and sometimes it doesn't understand me. A simple button would save time. Quote Link to comment Share on other sites More sharing options...
flymore Posted June 29, 2019 Author Report Share Posted June 29, 2019 On 6/15/2019 at 9:18 PM, onyxbfly said: I definitely agree that a source button would be helpful but with all of the available sources you would still need to do navigate to your preferred source. You can use the buttons on the right side of the steering wheel to interact with the right side IPC and navigate your sources. Or you can hit the sound button and that will pull you out of android auto/ car play and you can interact with your sources that way. You can set the cruise control to your preferred speed. You just have to start it and stop it manually. I am not aware of any car that engages cruise control as soon as you start your car. Climate control is set to resume the last setting. If you have dual climate on it will be on when you star your car. The only way that changes is if the passenger decides to make a change to their temp etc. If you do not go back into climate control to set it back to dual then it will resume the individual settings until you switch it back to dual. HTH No I don't mean cruise is "engaged" when you start the car. My Chevy had a switch for cruise you left it on, it was ON when you started the car then when the car was moving you press SET to engage it. With the Edge you always have to turn it on then press SET. Turn it on then press set. Turn it on then press set. With Chevy it's on so you just press set. Just press set at the speed you want above 25mph. Just press set at the speed you want above 25mph. With my Edge it doesn't remember that I left DUAL on so I can have different temperature than the passenger side. Every time I turn the car on I have to set DUAL and turn on cruise control. Start the car set DUAL in climate and turn on cruise control. Start the car set DUAL in climate and turn on cruise control. I'm now using the buttons on the right hand of the wheel to navigate to source, but it's several steps and I sometimes have to take my eyes off the road. Quote Link to comment Share on other sites More sharing options...
akirby Posted June 29, 2019 Report Share Posted June 29, 2019 30 minutes ago, flymore said: With the climate control I have to go in menus and turn on DUAL, so my wife can have a different temperature on her side of the car than mine. Would like to have DUAL on by default, there is no safety issue here with DUAL climate. I don't see the risk with leaving the cruise on, it doesn't engage unless you press SET and the car is moving over 25mph. So how is having the cruise off safer? Yes I can change the source with a voice command, I have to hold down the voice command button, wait for it to stop speaking then say what source I want and sometimes it doesn't understand me. A simple button would save time. All you need to do to set dual mode is change the passenger temp. You don’t need the menu. 1 Quote Link to comment Share on other sites More sharing options...
flymore Posted June 29, 2019 Author Report Share Posted June 29, 2019 Ok, I'll try just having her change the temp. I noticed that if I change the temp on my side, it changed both sides. I'll have her try it. Thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted June 29, 2019 Report Share Posted June 29, 2019 As for cruise control every modern car I’ve seen forces you to turn on cruise each time. It’s a safety feature so you don’t accidentally hit resume or set not realizing cruise was turned on. Most people don’t use cruise control every time they drive. I just hit on the. Set the first time. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 29, 2019 Report Share Posted June 29, 2019 6 hours ago, flymore said: Yes I can change the source with a voice command, I have to hold down the voice command button, wait for it to stop speaking then say what source I want and sometimes it doesn't understand me. You don't have to hold the button. Just press & release. Also, if you're familiar with the commands, you can switch voice commands to advanced which will skip most of the talk back you get from the system. Then, pressing the voice commands button the 1st button will give you beep & then you can say the command. 2 Quote Link to comment Share on other sites More sharing options...
flymore Posted June 29, 2019 Author Report Share Posted June 29, 2019 9 hours ago, omar302 said: You don't have to hold the button. Just press & release. Also, if you're familiar with the commands, you can switch voice commands to advanced which will skip most of the talk back you get from the system. Then, pressing the voice commands button the 1st button will give you beep & then you can say the command. The touch and release, doesn't always work...So with my Edge it's more of a hold and release. I'll look for the advanced option and try that when i get a little more familiar with the system. thanks Quote Link to comment Share on other sites More sharing options...
