cv27 Posted May 12, 2019 Report Share Posted May 12, 2019 2019 Titanium 2.0 AWD - When opening the driver's door (maybe others ?), I consistently hear a 1 second sound apparently from underneath like a wire rubbing against metal. Anybody else? Explanation? Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 13, 2019 Report Share Posted May 13, 2019 Is it only when first opening the door to go in the car while it is off? And it does NOT come if the engine is already running? Is so then it is probably the fuel pump priming to build up pressure getting ready so when you start the engine it starts easier. 2 Quote Link to comment Share on other sites More sharing options...
cv27 Posted May 13, 2019 Author Report Share Posted May 13, 2019 Sounds logical. I'll do a few tests (car on/off). 1 Quote Link to comment Share on other sites More sharing options...
mvan231 Posted May 30, 2019 Report Share Posted May 30, 2019 On 5/13/2019 at 6:49 PM, cv27 said: Sounds logical. I'll do a few tests (car on/off). I just got a 2016 2.0L and noticed the same thing. It's hard to hear it when you have the engine running, but I believe the noise you're describing is what omar302 was mentioning. Quote Link to comment Share on other sites More sharing options...
lildisco Posted May 31, 2019 Report Share Posted May 31, 2019 On my 2016 2.0, i only hear the fuel pump prime when my foot is on the brake before i hit the push button start. Don't hear it any other time, unless they changed something on the 2019's Quote Link to comment Share on other sites More sharing options...
Nolan Posted June 4, 2019 Report Share Posted June 4, 2019 Have a 2019. I think it is the fuel pump. Owned a Harley-Davidson that when I turned the key on, it made that same noise. Had to wait until a light on the dash shut off before starting it. Quote Link to comment Share on other sites More sharing options...
mvan231 Posted June 5, 2019 Report Share Posted June 5, 2019 I hear it sometimes on my 2016 in the same scenario, but it doesn't happen all the time Quote Link to comment Share on other sites More sharing options...
