Menthol Posted May 12, 2019 Report Share Posted May 12, 2019 Hi, I'm new to forum and a 2014 Edge SE with no push button start and no power liftgate. Can some help me find the correct kit to add remote start. I saw a few post down but that person had the power lift gate option. I found the kit on Ebay but not sure if it correct or can be found at a better price. TIA https://www.ebay.com/itm/2011-2014-Ford-Edge-Remote-Start-Plug-and-Play-Easy-Install-DIY-3X-Lock/113595028583?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D57475%26meid%3Dca9ecc535aad40a5a75b4d0cae385bc8%26pid%3D100005%26rk%3D2%26rkt%3D12%26sd%3D253685995654%26itm%3D113595028583&_trksid=p2047675.c100005.m1851 Quote Link to comment Share on other sites More sharing options...
candurin Posted May 12, 2019 Report Share Posted May 12, 2019 (edited) https://www.fordedgeforum.com/topic/17035-adding-oem-remote-start-kits-parts-explained-detailed-2011/ Just FYI, that is not a factory kit. Edited May 12, 2019 by candurin Quote Link to comment Share on other sites More sharing options...
Menthol Posted May 12, 2019 Author Report Share Posted May 12, 2019 14 minutes ago, candurin said: https://www.fordedgeforum.com/topic/17035-adding-oem-remote-start-kits-parts-explained-detailed-2011/ Just FYI, that is not a factory kit. Thanks. Will do some reading up. Quote Link to comment Share on other sites More sharing options...
Menthol Posted June 28, 2019 Author Report Share Posted June 28, 2019 (edited) Ok, so I bought this unit from Ford Fairway, (living in Canada and trying to buy some stuff from the USA can be a PIA) anyway I finally got it but did not install as yet. It came with one key, I took the key to an Auto Service centre ( Canadian Tire) and was told I can only get it programmed at the dealership. is this accurate? Can I not get it cut and do the FOB-learning process or is that different from the key programming? https://www.ebay.com/itm/11-thru-14-Edge-OEM-Genuine-Ford-Remote-Starter-Kit-Single-Key-FACTORY-NEW/161653104823?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l9372 Here is the reason for my asking. I had also bought a knockoff key (without remote start button) from ebay and had it cut at Home Depot for free, buddy said i'm SOL if it does not work. I did the FOB learning process and it would lock and unlock the doors but the key does not start engine. Why? did I get a dud or is the FOB learning process in manual different from key programming from the dealership. I don't want to screw up the OEM key that came with the remote starter. I would like to do this complete instal myself. I have the Forscan info for Hood Switch and Remote start. I think I can. I already did the turn signal to 6 blinks instead 3. Thanks for your replies. Edited June 29, 2019 by Menthol add link Quote Link to comment Share on other sites More sharing options...
Menthol Posted June 29, 2019 Author Report Share Posted June 29, 2019 (edited) Nevermind, I didn't know it was 2 processes. One for the FOB and one for the key. Edited June 29, 2019 by Menthol Quote Link to comment Share on other sites More sharing options...
Menthol Posted July 1, 2019 Author Report Share Posted July 1, 2019 (edited) Ok, I've hit a hiccup. Vehicle 2014 SE, no heated seats or wheel and no power liftgate. I've installed the antenna and hood switch. I've set the remote to on and the options on the display, the key working to lock/unlock and start car. The remote start will not work. I cannot find the option in BCM (not as built) to enable the hood switch or perimeter alarm. Those 2 options are not in there. Can someone help with this. I have the adapter hooked up to a netbook and it seems to be functioning correctly as I was able to change the number of signal blinks, set the remote on (0148) and set it to show in the display (IPC change) last setting or auto for the remote start temperature setting. Any help will be appreciated. Edited July 1, 2019 by Menthol Quote Link to comment Share on other sites More sharing options...
Menthol Posted July 1, 2019 Author Report Share Posted July 1, 2019 Ok, nevermind again, I found the problem, me. Even thought the option of perimeter alarm or Hood switch does not show up in BCM, it works. I was not pressing lock before the 2X twice. Hope this help someone. Quote Link to comment Share on other sites More sharing options...
