dawastemaster Posted May 6, 2019 Report Share Posted May 6, 2019 I recently purchased a 2019 Titanium 2.0L for my wife. We have approximately 3000 miles and I've noticed the tailpipes are extremely sooty. That was after a 400 mile run on the Interstate. I have a 2016 F-150 with 5.0L and there has never been soot in the tailpipe. Is this a case of burning too rich or something normal with these 2.0L engines? Quote Link to comment Share on other sites More sharing options...
lildisco Posted May 6, 2019 Report Share Posted May 6, 2019 Direct Injection & boost (turbo). Most manufacturers will run a boosted vehicle more 'rich' to decrease the chances of Detonation. It's better to run a little rich than lean. When in boost, which you're nearly always in on take offs & passing, the engine requires more fuel. To lesson the chance of running lean & potentially destroying the engine, manufacturers run the cars more on the rich side to prevent this. A tune will help lesson this, but will not eliminate it. I myself went on a road trip & notice soot on the exhaust pipes, but not terrible. I recently got a tune from Livernois tuning & it's brought the soot down dramatically (my LTFT, Long Term Fuel Trim, was at 6% or under most of the trip. Saw a lot of 1's & 3's compared to 9's & 10's prior to the tune). Another factor is the fuel you use. All fuel isn't created equal. Check out TopTiergas.com & find a station that is certified with it, it will be beneficial in the long run. I do use Mothers Metal polish occasionally to brighten up the tips from time to time, but usually, they clean up nicely after going through the self car wash using a pressure washer. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 6, 2019 Report Share Posted May 6, 2019 Using oxygenate fuels such as ethanol will also cut down on the soot. Unfortunately, you also would need a tune for the engine to run properly as it takes at least E20 to show the results. Quote Link to comment Share on other sites More sharing options...
todd92 Posted May 6, 2019 Report Share Posted May 6, 2019 DI engines produce more soot. Quote Link to comment Share on other sites More sharing options...
