Broke engine oil dipstick
paker
While doing the cooling system repair, I broke the handle of the dipstick. I should have removed it beforehand.
My plan was to drill a small hole, drive a screw in, and pull the screw. To my surprise, the dipstick slipped further into the engine (not completely) and wouldn't let me drill a hole. Does anybody have a suggestion? Will it completely fall into the engine? Or bottom out?
Thank you.
Edited by paker
As I understand the oil pan, the dipstick is on it's own 'chamber' behind a one way valve. So I don't think you're in danger of it getting into any rotating parts but it may not be easy to get a hold of it to remove. If there's no metal to get a magnet to stick to, some double sided tape on a wood dowel may work. Wrap the tape securely so it doesn't end up in there as well.
Edited by darkstarmoto
  • 5 years later...
