Water pump weep hole
paker
There are two weep holes.  The "minor" one is in the engine valley and can be seen with some effort and a strong light, towards the bottom left of the intake manifold.  The "major" one, where the BIG leak tends to happen is above the alternator/compressor, so to the side of the block.  Again difficult to see.  A borescope might make it easier in both cases.
This is true for ALL 3.5/3.7 engines used in the Edge/MKX.  Also of the 3.5 Ecoboost engine used in the transverse configuration.
