Degas procedure after cooling system repair?
paker
2010 3.5L
I wonder if there is a special procedure to remove air from the cooling system. I searched the owner's manual and this forum, but found none.
Thank you.
EDIT: It's been a while since I had to replace the radiator. Coolant level at the degas tank stays same. I wonder if the thin hose from the thermostat housing to the degas bottle does the trick of degassing. Thank you.
Edited by paker
