Intermittent Engine Miss Fire
argos587
Have 2008 Edge. Engine has a miss fire after multiple restarts. Such as running errands and stopping at different locations in succession.
Only received one code - #2 injector, however that was one time in about two months and has not reset. The miss fire continues, no codes so doubting it's the injector. No miss fire if car sets for an hour or more. Any ideas?
How many miles on your Edge?  Plugs/coils ever been serviced?
Did you try clearing codes, and if so, did it return?  If it returned, replace all the plugs and the pcv valve along with that #2 injector at minimum.  It is a matter of when not if that injector will fail completely.  Also make sure the coils look fine visually, and have acceptable resistance readings.  Otherwise, the PCM would be at risk.
On a temporary basis, you can try Techron Concentrate Plus or BG 44K to clear out any deposits in the injectors.
Edited by WWWPerfA_ZN0W
