Sage Posted April 4, 2019 Report Share Posted April 4, 2019 When I put my ST in Sport Mode, the exhaust seems to be enhanced in the cabin by use of the speakers? I have read others that have stated it is the same for them as well. I have read a couple of posts that stated on later built ST's there is no enhancement (my ST is an early built). I have been working with a Ford Service Advisor and he sent a request to Ford, using an internal system, asking how to turn that off. Below is the reply he got back from Ford, note: it is a screen shot that was sent to me by email. Not sure how visible it will be, but the reply was that the ST does not have a system called ESE system, there for it does not pipe in exhaust tone, so nothing to turn off. Comments, does some else know better - been told something different? Thanks Quote Link to comment Share on other sites More sharing options...
Fingernip Posted April 4, 2019 Report Share Posted April 4, 2019 You can disable it with Forscan but you will also lose active noise cancellation. There are threads about it on here somewhere. Also its BS that they deny it as it is also in all of the literature and I personally heard the difference between the car i test drive (early build) and my car (later build) that either has it toned way down or inactive. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted April 5, 2019 Report Share Posted April 5, 2019 Agree with the above. The Ford rep who replied is either unaware or misleading. It's possible that ONLY the engine noise can't be turned off (as mentioned above it'll also turn off noise cancellation) but it's definitely there on our early build and definitely NOT a natural exhaust sound. Quote Link to comment Share on other sites More sharing options...
Sage Posted April 5, 2019 Author Report Share Posted April 5, 2019 The dealership advisor has gone back to Ford with the added info for followup. Quote Link to comment Share on other sites More sharing options...
ONEDGE16 Posted April 5, 2019 Report Share Posted April 5, 2019 Here's the Forscan info most people are using to disable it: Engine Noise Enhancement disabled (Piped in engine noise): ACM 727-01-01 xxxx xXxx xxxx 2 = Enabled 0 = Disabled 1 Quote Link to comment Share on other sites More sharing options...
Sage Posted April 5, 2019 Author Report Share Posted April 5, 2019 On 4/5/2019 at 10:55 PM, ONEDGE16 said: Here's the Forscan info most people are using to disable it: Engine Noise Enhancement disabled (Piped in engine noise): ACM 727-01-01 xxxx xXxx xxxx 2 = Enabled 0 = Disabled Expand Thanks for the info Quote Link to comment Share on other sites More sharing options...
Beefnuts Posted May 28, 2020 Report Share Posted May 28, 2020 I put my setting to 0 and I am still getting a very noticeable hum through my after market amp and sub. I have tried grounding my amp I two locations and the hum is always at the same rpm. Anyone else still getting a hum after disabling the system? 1 Quote Link to comment Share on other sites More sharing options...
handfiler Posted May 29, 2020 Report Share Posted May 29, 2020 On 5/28/2020 at 9:44 PM, Beefnuts said: I put my setting to 0 and I am still getting a very noticeable hum through my after market amp and sub. I have tried grounding my amp I two locations and the hum is always at the same rpm. Anyone else still getting a hum after disabling the system? Expand If the amp has gain control, you might have it set too high. I had this issue on a previous installation and corrected it by turning it down a tad and letting the volume on the head unit do its thing. Quote Link to comment Share on other sites More sharing options...
Dingle Posted May 29, 2020 Report Share Posted May 29, 2020 On 5/28/2020 at 9:44 PM, Beefnuts said: I put my setting to 0 and I am still getting a very noticeable hum through my after market amp and sub. I have tried grounding my amp I two locations and the hum is always at the same rpm. Anyone else still getting a hum after disabling the system? Expand The setting in the ACM isn't enough to turn off the fake engine noise, it also has to be turned off in the DSP. Note this also disables ANC (active noise control) 783-01-01 Cxxx xxxx xxxx 2 1 Quote Link to comment Share on other sites More sharing options...
joselias78 Posted December 19, 2021 Report Share Posted December 19, 2021 (edited) There is a D on the firsth line.. 783-01-01 Cxxx xxxx xxxx so l have to change Dxxx by Cxxx ? Quote Edited December 19, 2021 by joselias78 Quote Link to comment Share on other sites More sharing options...
