When to change my back rotors? Already 160,000 km!
Hi. On my car already 160,000 km. After winter I have inspected the rear and front rotors. I have replaced front rotors and pads with 120,000 km and they as it should be. But my rear rotors, they are worn-out approximately on 0.7 mm from each party of rotor. Last year I have replaced rear brake shoes, but I did not change rotors and now thickness of rotor about 17 mm. When to change my rear rotors or it is still quite normal? Any thoughts. Thanks!
General Specifications
Item Specification
Front Brake Disc
Maximum brake pad taper wear (in any direction) 3.0 mm (0.118 in)
Minimum brake disc thickness 26 mm (1.023 in)
Minimum brake pad thickness 3.0 mm (0.118 in)
Rear Brake Disc
Minimum brake disc thickness 16 mm (0.629 in)
Pretty close to the rear rotors being worn out.
