Patches62 Posted April 2, 2019 Report Share Posted April 2, 2019 Just got a used 08 Edge....activated Siriusxm and it shows channels but has no audio. The unit shows UO 197 SAT. Any ideas??? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 3, 2019 Report Share Posted April 3, 2019 Pinpoint Test AG: DTC U0197 Or DTC U0197:00 Normal Operation Several audio system modules receive network messages from the Accessory Protocol Interface Module (APIM) via the Medium Speed Controller Area Network (MS-CAN). As more than one module receives each of these messages, all modules receiving a particular message should exhibit a symptom if the message is missing. DTC U0197 (Lost Communication With Telephone Control Module) — set by the non-navigation Audio Front Control Module (ACM) and the Satellite Digital Audio Receiver System (SDARS) module when network messages are missing from the APIM for greater than 5 seconds with the ignition in RUN. DTC U0197:00 (Lost Communication With Telephone Control Module: No Sub Type Information) — set by the navigation ACM , the audio Digital Signal Processing (DSP) module, or the Global Positioning System Module (GPSM) when network messages are missing from the APIM for greater than 5 seconds with the ignition in RUN. This pinpoint test is intended to diagnose the following: Communication network concern Audio system concern APIM Poor sound quality/no sound while in satellite radio mode — all other functions operate correctly Satellite radio antenna Satellite radio antenna cable Wiring, terminals or connectors ACM (vehicles with navigation) SDARS module (vehicles without navigation) 2010 Edge_Poor Reception-Poor Sound Quality-No Sound — Satellite Radio Without Navigation.pdf 1 Quote Link to comment Share on other sites More sharing options...
