zepher Posted July 1, 2008 Report Share Posted July 1, 2008 Hi all, Last year I got a Edge and I thought it came with the factory alarm system, which associated with the key. Is this true? Do I need to install another alarm system for it? Thanks, Max Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted July 1, 2008 Report Share Posted July 1, 2008 (edited) Hi all, Last year I got a Edge and I thought it came with the factory alarm system, which associated with the key. Is this true? Do I need to install another alarm system for it? Thanks, Max Hi zepher. :D You do not mention a year (2007 etc.) or trim level (SE, SEL etc.), so without researching whether all Edge models came standard with an alarm from the factory, I can't answer your question off the top of my head. However, you can find out yourself. So to put your mind at ease, do the following: 1 - Go out to your Edge and roll the drivers window down 2 - Exit the vehicle and lock the doors with the keyfob (remote button). 3 - Go into your house (or sit on your front steps for a minute of two). 4 - After a minute or two, reach in through the open window and open the door using the inside door handle (do not unlock the car first). 5 - If you have an alarm, it will sound off. If you hear nothing, you do not have a factory alarm system. Hope this helps. Good luck. :beerchug: Edited July 1, 2008 by bbf2530 Quote Link to comment Share on other sites More sharing options...
zepher Posted July 1, 2008 Author Report Share Posted July 1, 2008 Thanks a lot. My edge is 2007 SE standard. I would try it today. :-) Hi zepher. :D You do not mention a year (2007 etc.) or trim level (SE, SEL etc.), so without researching whether all Edge models came standard with an alarm from the factory, i can't answer your question off the top of my head. However, you can find out yourself. So to put your mind at ease, do the following: 1 - Go out to your Edge and roll the drivers window down 2 - Exit the vehicle and lock the doors with the keyfob (remote button). 3 - Go into your house (or sit on your front steps for a minute of two). 4 - After a minute or two, reach in through the open window and open the door using the inside door handle (do not unlock the car first). 5 - If you have an alarm, it will sound off. If you hear nothing, you do not have an factory alarm system. Hope this helps. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
