vega Posted March 17, 2019 Report Share Posted March 17, 2019 OK, I have removed these assemblies before but it was very hard to do. I done this on hundreds of cars but My 2015 Edge headlamps are very stubborn to remove. Last time I had to remove or loosen much of the grill assembly top in order to get the units out. Also, I done both push them in, or pushed them out, to remove. Anyone have an insight as to why they are so stubborn or am I doing something wrong? I installed my hids last time and this time wish to access the area under each to put in corner DRL's. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted March 17, 2019 Report Share Posted March 17, 2019 the hardest part is getting the bottom piece right. I've had my Edge headlights out about 15 times probably in 3 years. I can literally remove both headlights under 5 mins. It does take longer to get them in, unless you get lucky and the bottom goes in the right spot at the right time. 1 Quote Link to comment Share on other sites More sharing options...
vega Posted March 17, 2019 Author Report Share Posted March 17, 2019 On 3/17/2019 at 7:16 PM, Nick Halstead said: the hardest part is getting the bottom piece right. I've had my Edge headlights out about 15 times probably in 3 years. I can literally remove both headlights under 5 mins. It does take longer to get them in, unless you get lucky and the bottom goes in the right spot at the right time. Expand I can't tell from your picture, but when you remove them do you also have to remove or loosen that plastic cover just above the radiator and grill? Quote Link to comment Share on other sites More sharing options...
