Ford My Touch
Motorhomer
We recently bought a 2013 Edge Limited.  Love it except for the dinging bell and the messages in the left display.  It gives us many error messages and the dinging bell.  Messages include Driver door ajar, Shift to park, engine running,
Rear hatch ajar and others.  The My Touch system is the original and Ford won't update so what SD card do I need to buy to update system?
Hopefully the update will cure some of these problems, I already did a factory reset which may have helped a little but very little.
Welcome to the forum!
Not the most pleasurable way to get initiated into Edge ownership. Luckily the members of the forum are here to sort you out!
Updating My Touch will not resolve your issues. Please see below for forum posts that detail how to resolve your issues:
Liftgate Ajar:
https://www.fordedgeforum.com/topic/26116-liftgate-ajar-message/
Door Ajar:
https://www.fordedgeforum.com/topic/20356-2013-ford-edge-driver-door-ajar-light-always-on/?do=findComment&comment=150938
Shift to Park:
https://www.fordedgeforum.com/topic/21925-edge-shift-to-park-warning-message/?tab=comments#comment-164499
https://www.fordedgeforum.com/topic/26500-shift-to-park-message-resolved-diy-2011-mkx/?page=0#comment-197631
Other things to be aware of is that the My Touch interface has an open recall. You should call the dealership and see if your Edge is eligible.
Another possible issue if your Edge is AWD, you should have the fluid drained and filled ASAP.  Ford says the fluid is a lifetime fluid. Others myself included will tell you not so much.
Your issues are relatively easy to resolve. They can be resolved via DIY depending on your level of skill and comfort etc.
Good luck and enjoy your new ride!
Edited by onyxbfly
