rhoov Posted March 9, 2019 Report Share Posted March 9, 2019 The manual mentions this panel is under the instrument panel to the left of the steering column. There is a removable cover but there is nothing behind it. The manual also mentions possibly removing the trim but is not specific. I give, anyone able to shed some light on this? Quote Link to comment Share on other sites More sharing options...
jamie1073 Posted March 9, 2019 Report Share Posted March 9, 2019 41 minutes ago, rhoov said: The manual mentions this panel is under the instrument panel to the left of the steering column. There is a removable cover but there is nothing behind it. The manual also mentions possibly removing the trim but is not specific. I give, anyone able to shed some light on this? If it is anything like the 2019 then it is against the firewall to the left of the brake pedal and faces the brake pedal instead of the dash so you can barely see it with that cover removed. Strange since that cover is so big and really they could have done without it since you can't really see anything without getting under the dash. Quote Link to comment Share on other sites More sharing options...
Platinum White Posted May 20, 2019 Report Share Posted May 20, 2019 (edited) Another marvelous thing produced by designers/engineers who NEAVER work on a vehicle. Edited January 21, 2020 by Platinum White 1 Quote Link to comment Share on other sites More sharing options...
Gotts2Go Posted February 27, 2020 Report Share Posted February 27, 2020 Just a side note... If you have heated steering, it is impossible to replace fuses in that panel without first removing the heater module. It's held on with two 10mm bolts and the wire harness (accessible from that access panel). I suggest keeping a small 1/4" rachet and a 10mm socket in your trunk for roadside emergencies. Quote Link to comment Share on other sites More sharing options...
