flymore Posted March 7, 2019 Report Share Posted March 7, 2019 (edited) Bought a CPO Edge over the weekend and enjoying it. Two problems, 1st, Noticed a windshield a sticker that said Valvoline conventional oil change about 3000 miles ago. Manual says, "Recommended motor oil (U.S.): Motorcraft® SAE 5W-20 Premium Synthetic Blend Motor Oil XO-5W20-QSP" So whoever had this vehicle before me used conventional oil! ? 2nd, After the test drive noticed the oil percentage down to 39% so asked about an oil change at the dealer... salesman said, "oh they just didn't reset it". Really! Picked the car up a day, they were going to reset it... now reads 37%, so they didn't reset it. The oil looks clean, but the oil monitor now reads 36%. I'm thinking I'll change it when it gets down to 10%. What kind of damage was done to this engine running conventional motor oil through it the first 28,000 miles? I'm intending on keeping the vehicle. Thanks Edited March 7, 2019 by flymore Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 7, 2019 Report Share Posted March 7, 2019 If the oil was changed frequently, and it met the API SN spec, should be fine. I would have the oil changed immediately to full synthetic, and the IOLM set to 100% if you intend to rely upon it. It seems paradoxical to let the IOLM run down based on someone else's assertion about the oil change, and you intention to be a longterm owner of the vehicle. Such a small cost for peace of mind. I assume you have the 3.5L engine in your Edge, since 5W20 is being used? Quote Link to comment Share on other sites More sharing options...
flymore Posted March 7, 2019 Author Report Share Posted March 7, 2019 18 minutes ago, WWWPerfA_ZN0W said: If the oil was changed frequently, and it met the API SN spec, should be fine. I would have the oil changed immediately to full synthetic, and the IOLM set to 100% if you intend to rely upon it. It seems paradoxical to let the IOLM run down based on someone else's assertion about the oil change, and you intention to be a longterm owner of the vehicle. Such a small cost for peace of mind. I assume you have the 3.5L engine in your Edge, since 5W20 is being used? I can only hope the oil was changed "frequently" up till now. Hence the risk of purchasing a used car. The oil looks clean right now, so it appears it was changed at the dealer and they didn't reset the OLM. I''ve always used the OLM in my previous cars, so why not use it now? Yes, 3.5L. Quote Link to comment Share on other sites More sharing options...
flymore Posted March 7, 2019 Author Report Share Posted March 7, 2019 How do I get the bottom cover off to get to the oil filter and drain plug? Thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted March 8, 2019 Report Share Posted March 8, 2019 1 hour ago, flymore said: How do I get the bottom cover off to get to the oil filter and drain plug? Thanks Ummm.....you remove the screws around the perimeter. You’ll need a Torx bit or screwdriver. 1 Quote Link to comment Share on other sites More sharing options...
SUV-E Posted March 8, 2019 Report Share Posted March 8, 2019 Ask the dealer what oil they put in it. If you are ok with it, then fine. Personally, I would change it and put in full synthetic, and consider the dealer change a good flush of the system. Quote Link to comment Share on other sites More sharing options...
flymore Posted March 8, 2019 Author Report Share Posted March 8, 2019 9 minutes ago, SUV-E said: Ask the dealer what oil they put in it. If you are ok with it, then fine. Personally, I would change it and put in full synthetic, and consider the dealer change a good flush of the system. Yea, that's what I'm planning on doing. Main concern is how the conventional oil may have caused wear inside the engine when Synthetic Blend is recommended by ford and GM and it may sound like this someday, Thanks Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 8, 2019 Report Share Posted March 8, 2019 Wouldn't worry about the past. These engines can last a good LONG time. Just take care of it going forward. Quote Link to comment Share on other sites More sharing options...
evh Posted March 8, 2019 Report Share Posted March 8, 2019 (edited) I think you are ok. My 2009 3.5L Edge says to use the Motorcraft Semi-Synthetic but has a note on it that reads " Use of synthetic or semi-synthetic blend motor oil is not mandatory. Engine oil need only meet the requirement of Ford Specification WSS-M2C930-A and the API Certification mark." My 2016 3.5L Edge spec says to use Motorcraft Semi-Synthetic as well and says it must meet spec WSS-M2C945-A. See the following links. What I gather is the conventional oils meet this spec. The second link is the spec sheet for Valvoline 5W-20 conventional motor oil. It says it meets WSS-M2C945-A. https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2604859 https://sharena21.springcm.com/Public/Document/18452/a2457451-fe75-e711-9c10-ac162d889bd3/bab4d631-93bb-e711-9c12-ac162d889bd1 ** Note - I bought my 2009 used in 2010 with 65,000 miles on it. It was a fleet vehicle for a business salesman (reason for the high mileage). He had all the records and took it to a Valvoline quickie lube shop to have the oil changed. I bet they used the cheapest Valvoline 5W-20 conventional for the first 65,000 miles. When I got it, I have only used the 5W-20 Motorcraft Semi-Sythetic oil (it's pretty cheap at Wally World). I now have 225,000 miles and it doesn't burn any oil. I wouldn't worry. Edited March 8, 2019 by evh 1 Quote Link to comment Share on other sites More sharing options...
flymore Posted March 8, 2019 Author Report Share Posted March 8, 2019 (edited) Yes, the WSS-M2C945-A is in my owners manual as well. So I think I'm ok too "fingers crossed" and I'll go full synthetic going forward. I'll save that valvoline link in case there's some question for warranty. It's not so much the burning of oil I'm concerned about, it's the wearing of those chain guides. When do you guys change oil? I've always used OLM in my GM cars. The GM dealer recommended changing the oil when the OLM gets down to around 10% and that's what I always did in my GM 3.6L. But the Ford dealer said they changed the oil and it's clean so I think they did, but didn't reset the OLM. Who doesn't do that! Edited March 8, 2019 by flymore Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 8, 2019 Report Share Posted March 8, 2019 The spec number differences are for two different viscosities of oils - 945 is 5w20, 946 is 5w30. Does not intimate higher quality. Quote Link to comment Share on other sites More sharing options...
flymore Posted March 8, 2019 Author Report Share Posted March 8, 2019 19 minutes ago, WWWPerfA_ZN0W said: The spec number differences are for two different viscosities of oils - 945 is 5w20, 946 is 5w30. Does not intimate higher quality. Yea but the 946 is for the 2.0 and 2.7 litre not the 3.5 litre. Correct? I have the 3.5L so I must use the 5w20 not the 5w30. Correct? thanks Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted March 8, 2019 Report Share Posted March 8, 2019 18 minutes ago, flymore said: Yea but the 946 is for the 2.0 and 2.7 litre not the 3.5 litre. Correct? I have the 3.5L so I must use the 5w20 not the 5w30. Correct? thanks You are correct! Quote Link to comment Share on other sites More sharing options...
evh Posted March 8, 2019 Report Share Posted March 8, 2019 I corrected my post above where I said the Valvoline link said their conventional 5W-20 met the WSS-M2C946-A spec. That was incorrect. It meets the WSS-M2C945-A spec. 1 Quote Link to comment Share on other sites More sharing options...
flymore Posted March 8, 2019 Author Report Share Posted March 8, 2019 (edited) I'd like to use 5w30, have some Mobil 1 left over from my Chevy 3.6l I'll probable sell to my buddy or use it in the wife's car. Funny thing, the Ford 3.5L uses the same oil filter as my Chevy 3.6L used, so those two extra oil filters I have are good! Edited March 8, 2019 by flymore Quote Link to comment Share on other sites More sharing options...
evh Posted March 8, 2019 Report Share Posted March 8, 2019 "I'd like to use 5w30, have some Mobil 1 left over from my Chevy 3.6l I'll probable sell to my buddy or use it in the wife's car." Right, sell it to your buddy. Use only 5W-20. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 8, 2019 Report Share Posted March 8, 2019 If you live in a hot area of Texas, Arizona, Florida etc. you could probably use the 5W30 without detriment. But 5W20 full synthetic usually does well in non-extreme climates. Quote Link to comment Share on other sites More sharing options...
flymore Posted March 9, 2019 Author Report Share Posted March 9, 2019 1 hour ago, WWWPerfA_ZN0W said: If you live in a hot area of Texas, Arizona, Florida etc. you could probably use the 5W30 without detriment. But 5W20 full synthetic usually does well in non-extreme climates. Hahaha no, Tuesday morning was 6 degrees...not wind chill. Normal temperatures should be in the 40's here in Ohio. Oh well. The climate changes 4 times a year here! No, I won't be changing the oil till it gets into the low 50's and I'll use 5w20 full synthetic. I'm not in a hurry, the oil looks clean. I think(hope) the Valvoline sticker was from the oil change before the dealer got it and did the CPO inspection. So the dealer didn't take the Valvoline sticker off the wind-shield and reset the OLM after they changed the oil! HAHAHAHA The miles on the Valvoline sticker was 3000 miles before the mileage was when I bought it. The oil that's in it doesn't have 3000 miles on it, way to clean. Oh well, we like the vehicle and think we got a good deal. Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 9, 2019 Report Share Posted March 9, 2019 (edited) On 3/7/2019 at 4:00 PM, flymore said: I can only hope the oil was changed "frequently" up till now. Hence the risk of purchasing a used car. The oil looks clean right now, so it appears it was changed at the dealer and they didn't reset the OLM. I''ve always used the OLM in my previous cars, so why not use it now? Yes, 3.5L. When I recently bought my wife's 2015 Mustang from a private individual, CarFax did not show all the oil changes, so I waited for the seller to get copies of the service record from Bill Collins Ford, and only after confirmation that its service record was good did I make my decision to purchase - with all the electronic records etc. these days it reduces the risk buying used. Below is my Sport's records showing my DIY and the Dealership services. Edited March 9, 2019 by 1004ron 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 9, 2019 Report Share Posted March 9, 2019 I will repeat that you only have the dealer's word that the oil was serviced. Personally, paying for an oil change right away at a trusted mechanic is a small price to pay for peace of mind Some oils do not look dirty even with miles on them, for various reasons. Anyhoo, enjoy the Edge Quote Link to comment Share on other sites More sharing options...
flymore Posted March 9, 2019 Author Report Share Posted March 9, 2019 Been changing oil for 54 years. Old man had a trucking company, no diesels plenty of dock highs and semis. Guss who did the work. Too cold to change now. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted March 14, 2019 Report Share Posted March 14, 2019 Anyone have a problem with Wally full synthetic Supertech 5w20? Thinking about running it in my 2008 Taurus winter beater that has 85,000 miles on it. Quote Link to comment Share on other sites More sharing options...
flymore Posted March 17, 2019 Author Report Share Posted March 17, 2019 I've used Supertech in the past with no issue. You can search www.bobistheoilguy.com for comments or comparisons of oil. Mostly I use Mobil 1 now buy it when it's on sale. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 19, 2019 Report Share Posted March 19, 2019 As long as you do not get into extended interval oil changes, just about any full synthetic offtheshelf at WalMart will do just fine. So yes, SuperTech is good to go Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted February 11, 2020 Report Share Posted February 11, 2020 (edited) Guess I’m an old school change every 3K miles person. I’ve had the Edge since 17K, now 62K, and always used conventional (gasp, engine abuse) at various Ford dealers (!) and Firestone shops. So stay tuned for me reporting the motor blew up or the synthetic police have found me... I just can’t see that this engine, as lightly used as it is, will be harmed with up to date conventional oils changed out that often. Edited February 11, 2020 by 14AWD3.5 Typo Quote Link to comment Share on other sites More sharing options...
