Side Mirror Replacement
01Cobra
Anyone have the step process to this on the 15+edge? Specifically the painted cap. You are supposed to swap from old mirror to new. There is a certain way to get the clips to disengage and I don’t want to risk breaking them.
In search I could only find info on the previous gen cars.
Ended up getting it done but broke one of the clip points I didn’t see. It was a lower corner clip but between the other points and a little auto body double side mounting tape it’s on and tight.
Once I got the top clips released I should have inspected the lower corner.
Need to see if you can source just the black plastic bezel around the mirror and the turn signal to repair the old one just to keep around.
Edited by 01Cobra
