sabanist Posted February 24, 2019 Report Share Posted February 24, 2019 Hi, I'm new to the forum. Owned a 2007 edge since 07. The floor shifter light has been out a while as well as the climate control backlight I changed the bulb in the floor shifter light and it still does not light when i switch the lights on, or when i operate the dimmer. . I checked a bunch of different fuses and they all appear to be fine. Specifically i changed out the f30 5 amp fuse because i read that controls the floor shifter light. I pulled the headlight switch to see if i could tell anything wrong with it. I couldn't fit my multimeter on the metal connections for that wiring harness. I dont really know whats ground and whats hot when you pull the switch apart so i put it back together. Anyone had this problem, i read alot of internet articles but no solution was apparent. Thank s Quote Link to comment Share on other sites More sharing options...
