Dukhaykh Posted February 18, 2019 Report Share Posted February 18, 2019 My 2014 ford Edge is equipped with AWD, i wanna turn AWD off and just use FWD temporary, Is there any way that i can turn AWD off? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 18, 2019 Report Share Posted February 18, 2019 (edited) Pull the AWD/4x4 fuse? Check in owner's manual for location, but should not have anything else on that circuit. Oops looks like the A/C clutch relay is also on F70 in the BJB ... so no a/c related functions if you pull that fuse ... I suppose you could pull the connector off the AWD/4x4 module directly (located in the spare tire comparment, I believe). Edited February 18, 2019 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
Dukhaykh Posted February 18, 2019 Author Report Share Posted February 18, 2019 Thank you for your feedback, will try to find out the connector place ? 1 Quote Link to comment Share on other sites More sharing options...
Dukhaykh Posted June 28, 2019 Author Report Share Posted June 28, 2019 I tried to find the connecters but with no luck ? any other suggestion? Quote Link to comment Share on other sites More sharing options...
Dukhaykh Posted June 28, 2019 Author Report Share Posted June 28, 2019 Just now, Dukhaykh said: I tried to find the connecters but with no luck ? any other suggestion? I also did Pull the AWD fuse and it turned off but it also turned off the ABS and traction control!? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 29, 2019 Report Share Posted June 29, 2019 (edited) The connector should be at the front part (ATC) of the RDU, which looks like this. The connector is most likely on the top side. Edited June 29, 2019 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
Dukhaykh Posted June 30, 2019 Author Report Share Posted June 30, 2019 19 hours ago, WWWPerfA_ZN0W said: The connector should be at the front part (ATC) of the RDU, which looks like this. The connector is most likely on the top side. Thank you for your great information, I found the connector on the same place you described above and pulled it out. It is showing now on dashboard lights saying Check AWD. Now its FWD only. The question now, Is the ptu now still working and moving the drive shaft? If yes is there a way to stop it too ? 1 Quote Link to comment Share on other sites More sharing options...
Waldo Posted July 1, 2019 Report Share Posted July 1, 2019 Yes the PTU is still spinning the driveshaft. It is connected to the engine/transmission by a bunch of solid metal. There is no way to disconnect it. 1 Quote Link to comment Share on other sites More sharing options...
Dukhaykh Posted July 2, 2019 Author Report Share Posted July 2, 2019 I tried also to pull the fuse for ABS and I got different msg on the dashboard as you can see below: AWD off But as above picture, when I pull the back switch I got msg: Check AWD ! I don’t know if the first alarm means the ptu is off completely! 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 2, 2019 Report Share Posted July 2, 2019 13 minutes ago, Dukhaykh said: I tried also to pull the fuse for ABS and I got different msg on the dashboard as you can see below: AWD off But as above picture, when I pull the back switch I got msg: Check AWD ! I don’t know if the first alarm means the ptu is off completely! The PTU cannot be turned off. The prop shaft to the RDU will always rotate as long as the PTU is installed. 2 Quote Link to comment Share on other sites More sharing options...
Special_K Posted July 2, 2019 Report Share Posted July 2, 2019 This is good info, we are trying to develop a way to turn the AWD off and on by command. How far have you driven on this and have you noticed any side effects except not having AWD. Lastly, does the car go into limp mode at all? @snmjim 3 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 3, 2019 Report Share Posted July 3, 2019 On 6/29/2019 at 9:09 PM, Dukhaykh said: The question now, Is the ptu now still working and moving the drive shaft? If yes is there a way to stop it too ? Good question! I assume yes still spinning as Waldo said, since there is no electronic brain determining PTU-driveshaft connection, unlike in 2019. If the transmission is not in P or N, the driveshaft is always engaged. The only electronic connection 2007-18 is to the clutches in the ATC, so you can be confident the RDU is not in use. The PTU remains in full force, tho. You CAN remove the driveshaft completely to prevent that wasted effort. And quite a few people have done this, for months on end with no detrimental effect on the vehicle. You of course lose optimal handling capability, but if you stay out of extreme situations, should be much of an issue. 1 Quote Link to comment Share on other sites More sharing options...
Dukhaykh Posted July 3, 2019 Author Report Share Posted July 3, 2019 @Special_K Thank you for your feedback, I am thinking also to find out some Mods by Forscan May be! I usually take off the ABS fuse especially during race ? because I can see the difference in power ✈️ . I have driven my car for almost a year without any problems. I even installed a switch inside my car connected to the fuse to turn it off/on easily ? The problem with the fuse when you take it off the ABS system will shut off too. I am thinking now to use my current switch setups on the back clutch instead of using the fuse. Fuse box attached; Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted January 17, 2021 Report Share Posted January 17, 2021 I would wonder why bother turning it off/disabling it anyway? Mine seems to not cost me any mpg penalty based on sticker ratings, so what's the advantage? 2 Quote Link to comment Share on other sites More sharing options...
F4Gary Posted January 29, 2021 Report Share Posted January 29, 2021 Yes, why do you want it off? Just curious. Quote Link to comment Share on other sites More sharing options...
trav Posted December 29, 2021 Report Share Posted December 29, 2021 I would jump in here and say I would love to turn off the AWD on our Edge. It's a 2014, and we live in northern MN. I used to have a Nissan Rogue, where I could activate/deactivate the AWD, and I never once got stuck as a result. The Edge, on the other hand, we have been stuck once a winter that I can think of. It's super frustrating for the vehicle to be trying to tell me what the conditions are when I know what the conditions are. An on/off would be very helpful. I know the conditions of the roads better than the vehicle does. Quote Link to comment Share on other sites More sharing options...
akirby Posted December 30, 2021 Report Share Posted December 30, 2021 On 12/29/2021 at 9:36 AM, trav said: I would jump in here and say I would love to turn off the AWD on our Edge. It's a 2014, and we live in northern MN. I used to have a Nissan Rogue, where I could activate/deactivate the AWD, and I never once got stuck as a result. The Edge, on the other hand, we have been stuck once a winter that I can think of. It's super frustrating for the vehicle to be trying to tell me what the conditions are when I know what the conditions are. An on/off would be very helpful. I know the conditions of the roads better than the vehicle does. Are you turning off traction control? That’s probably what’s causing issues - it cuts engine power. In snow you need some wheel spin. I can’t imagine fwd being better than AWD when used properly. 3 Quote Link to comment Share on other sites More sharing options...
trav Posted January 4, 2022 Report Share Posted January 4, 2022 I will try this - thanks for the tip! Quote Link to comment Share on other sites More sharing options...
